- Thread starter
- #21
6
69redvette
You can eliminate the spring without buying a new one. Take it out and turn it 180 degrees and reinstall. If it's the same then it's not the spring. Also, you can pull the left rear tire and remove the small access panel in the front of the wheel well and check the body mount behind the drivers seat. See if it's rotted out.
Joe
Joe
As most have said, this is an older car, and the leaf spring technology is for each of the leafs to move on each other. Over time they don't get the service needed and also loose their arch. Most noteably is the fact that if you try to re-arch the spring, it is going back to origional, but it took time to get in the shape it's in now.. LOTS OF FLEXING HAS OCCURED. May be the best time to think about replacing it even with a stock spring. It could fail as a result of re-arching, or last... I would rather have a good spring under me..
