minifridge1138
Hey everyone, I need help!
Saturday I drove the car for several hours with no problems. It was 95 degrees outside. I stopped for dinner (took about an hour). Started the car, and within 30 seconds it stalled. It wouldn't restart. I popped the hood, took off the air cleaner. I saw fuel dripping onto the secondary throttle plates, fuel bubbling up the vent tube, and some coming out between the carb and the carb/intake gasket. Everything was so hot I could barely take off the air cleaner.
I let everything cool off. A friend suggest i tap on the back of the carb in case i had a sunk float. Then the car started with no leaks and everything seemed normal. I immediately drove the 30 miles home without any trouble.
What in the world happened? Vapor Lock? Stuck Float? Both?
I've never had vapor lock happen before, so I don't know what that would cause (other than a stopped car).
Any help is appreciated.
THANKS!
THANKS!
