JohnnyGordo
Guys, I know nothing of carbs for the most part. I have a 1981 Corvette with a Rochester E4ME Carburetor. I just replaced it because I was getting bad mpg, about 6. It was time to get one rebuilt, so I ordered a remanufactured one that was cleaned, rebuilt, and adjusted to OEM specs. Replacement was fairly easy.
So, I put in a new carburetor in (remanufactured, rebuilt, and adjusted to OEM specs), the same as was in the car. Followed everything to a T. Once completed, she fired right up and was idling very well...I was so happy...until I put it into gear. She bogs down so hard when you give it gas, she barely moves and will die, even when I give it gas. HUGE hesitations. When idling in park, the car is very responsive to gas, but once in drive or reverse, she runs terrible. I drove it a block and it died on me four times trying to get it home. I had to give it lots of gas in park, then slam it into gear to keep it running and to get it moving.
ad I'm about to put the old one back on if I can't get any help. PLEASE HELP!!!! Is she running lean, or rich, thought about adjusting mixture, but don't know how, I see two screw holes in the front on either side, however, looks like it needs a special tool and I have no idea how to get in there= bad placement. Is the mixture my problem?
