I agree, there shouldn't be enough pressure to blow it out. I DO have 104,000 miles on it. I do have typically 70-80lbs of oil pressure. I do have a high pressure and high volume oil pump. I was stupid, and did all my mods at about 95,000 miles on the motor. My theory, I guess goes with my age of 22 when I did the stuff, is when, not if, when I blow my engine, I will rebuild it to be a power house. I did the dual quads, full race cam, high reving hydraulic lifters, roller rockers, the racing heads, a piece here, and a piece there. I knew that when I did blow it, the whole top half of the engine is basically new, and will be used on the new engine. Anyways, my luck seemed to take a turn for the worse. Started my car, with full oil, sounds like a bad rod knock now =( Dad is coming over tomorrow to look at it. Nice.. Great... In college, no money to rebuild... But... Grants and loan money for school is coming in... hmm.. hehe. With about 9000 miles on the top half of the motor, it is basically brand new, and will save me a couple thousand on the new motor. I mean realistically, we can get machine work on the block out here for I think $700. Expensive parts are the heads, they are still new =) Just need a crank, and maybe 10.5 : 1 pistons, and the car should fly. should be able to do it for under $1k. The car ran 13.5 with what I have in it now, and I could have got a lot more out of the timing, but I drive it on the street, and don't have a high torque starter. I have it set to where she just starts on hot days. I once turned the timing down 1/8 of a turn, and had to lose 2seconds on 1/4mile. RPMS went no where. From my current setting, I can't turn it up more, the vacume advance *which isn't used, it was strobed and set up* hits the intake manifold. I need to take it out and swing it back so i can get more advance out of it. If 1/8 of a turn can slow me down that much... 1/8 forward.. hmm... And to think, I only have 8.5:1 compression now. You KNOW damn well, that cam is not even near it's potential with 8.5:1 compression. The heads can breath now, but with my current compression, not seeing anywhere near their potential either. I really believe, and have been told by a couple machine shops I know, that my current setup with 10.5:1 compression should easily see 11's =) Oh, FYI. I have dual quads, full race cam, Pro Line Heads *open chambered*, hooker header/sidepipes with JCL inserts, 4.11 rear end, 3000 stall speed, and a 700R4 trans. The car should fly with 10.5:1 compression!
