thomaswat
I can't seem to make my engine in my '65 ( rebuilt original 350hp ) with an Edelbrock 650cfm carb, idle properly. Sometimes it seems to be o.k., but other times with the idle set around 750-800rpm it will run for around a minute-more or less- and them just die like it's out of gas. If I bump the gas to keep it from dieing, it speeds up just fine, but in a minute it starts to die again. It doesn't happen every time, but more often than not. I try adjusting the screws on the carb and sometimes turning them just barely will help, but next time I drive it, it starts doing it again. The carb only has around 500mi. on it. This problem started after the engine was rebuilt. Lastly, if I set the idle speed to around 1100 or so, I doesn't seem to do it.
Tom
Tom
