Cast iron lt1 heads for '92
tomd
michigan
1992 coupe
I'm collecting parts for an engine rebuild this winter and have a chance to purchase new LT1 iron heads. Any potential problems I should be aware of? Thanks
I'd run as fast I could in the other direction - LT1 heads were aluminum. Last year for cast iron Vette heads was 1986.
[RICHR]
Most likely those heads are off a Caprice, Firebird, or Camaro. Im pretty sure the Vette LT1 heads are aluminium.
:pat
:w
:pat
:w
yes the cast iron is for passenger cars, if you need heads and a rebuild why not go LT4 GM performance parts has a kit to do just that a lt1 to lt4 conversion kit you can get it most anywhere speed parts are sold.
Hoorah bossvette :w
If you're looking for heads anyways ... why not go with the LT4's?
:w
All of the literature I've read about the iron heads says that they actually flow 20% better than the aluminum and I can buy them new for less than $200 each.
You'll be adding a substantial amount of weight to the front with the iron heads. I would also carefully check the port dimensions too.
