401KVet
I pulled the center gauges out to do a little work. Before putting it back in I'm checking to make sure all is working. I might be thinking of other car, but I seem to remember a check engine light coming on when I would start the engine and going off after a few seconds. It's the light on the left which also has the seat belt reminder in it. The seat belt is on the top portion and the check engine is on the bottom. Now the check engine light is not coming on as I THINK I remember. Now, reading my owners manual, the CHECK ENGINE light was only for cars made in California. Mine was not. So is my memory not what it use to be? Is there no check engine light there that should be working? I'm just wanting to be sure before I put all back togeather. I hoping that's the case and my manual is correct. I've had bad experience's with misprints in the past. Thanks,
