Radar
- Joined
- Oct 23, 2001
- Messages
- 200
- Location
- Oconomowoc, WI
- Corvette
- 1989 Medium Blue Metalic Convertible
I have an 89 convertble with the L98, 700R4 auto trans and 2:59 rear axle ratio.
I would like to change to the 3:07 or 3:31 rear gears for a little better punch from the hole. I still need a good highway cruiser so I don't want to go way up in ratios.
Has anyone tried this change?
I know that a change to the speedometer transmission tailshaft gears is needed. How difficult is it to change these speedometer gears? Is it necessary to pull the tail shaft off the 700R4 to change both gears or can you just change the plastic gear?
I know, lets get this over with so I only one more question. Does the 700R4 need any changes internally or will the shift points match up to the new axle ratios okay?
I can't wait for spring to get the Vette out and get this change installed.
Best Regards,
Radar
:xmas :confused
Best Regards,
Radar
:xmas :confused
