S
SYTECH
Second time will definately be easier, but 1st time sucked
Removed the intercoolers....no sweat
Removed the clamp from the intercooler down pipe and rotated the pipe out of the way.....no sweat
Drivers side plugs all came out with minimal cussing
Go to the passenger side
1st two plugs come out fine
Then its like..WTF, how in the hell can anyone short of a Chinese Acrobat or contorsionist manage to get the back two plugs out without pulling more parts off
I tried, and tried, and tried and finally decided to remove the 2 bolts mounting the intercooler downpipe, only to find out that someone from Ford must have engineered that fit cause i was going to have to remove the Turbo water fitting in order to get to one of the two downpipe bolts
So there I am, draining the radiator (via the turbo water line) just long enough to get the downpipe bolt out, and then re-installing the water line until after i change the plugs
I removed the downpipe and still had a ***** of a time getting the back plug out
Patience, patience, patience
Eventually it did come out, and the new plugs went in
Not the worst car to do the job on, but definately right up there with my Syclone & Typhoon
I should have done the plug wires at the same time but after the water line fiasco, they could kiss my a$$!
I did do the distributer cap & rotor but luckily that was also before the plugs
I love doing most of my work myself, but there are times when I reconsider my choice...lol
Later
Ray
Later
Ray
