Stallion said:I think it is about time I do this. How would you drain and put in new brake fluid? By what means would you accomplish this?
Thanks!!
TR
bobchad said:Three ways to bleed the brakes that I am aware of; gravity, pumping the pedal and using a pressure bleeder.
With gravity you let gravity drain the fluid from the system.
With pumping you have an assistant pump the pedal and hold it steady when you open the bleeder allowing the fluid to move through the system.
A pressure bleeded turns the pumping method into a one man job. I think most connect to the bleeder and suck the fluid out when you open the bleeder. I have read about those that fit on the top of the master cylinder and push the fluid through the system as well.
If you take it to a good shop, they will pressure bleed the system.
I bought a $20 pressure bleeder and was not happy with the job. That's why I took it to the shop.
Steve Grodin said:You should remove all of the old fluid from the master cylinder before doing a brake fluid change. Use something like your wifes turkey baster.
Stallion said:Wouldn't that be part of the draining? Wouldn't you get everything out of the whole brake system, including the master cylinder? Why wouldn't those ways (like gravity) get the fluid out of the master cylinder?
Steve Grodin said:You want to start the flushing of the brake system with FRESH brake fluid. I'm talking about DIY projects. I assume a professional shop wouldn't flush a brake system with old fluid in the MC.
Stallion said:I don't think I'm understand.When you drain the brake system, I assume that you take all the fluid out of it. And this would be the previously used brake fluid. And then wouldn't you just fill it up with new fluid?
