Aurora40
I put a new battery in the car, an ACDelco 75-6YR. And I drained out the oil, but couldn't find a local filter I trusted (dealers were closed, so it was a Purolator that was questionable as to whether it was the right one, or a Fram) so I'll change the filter tomorrow.
I had wanted to drain and refill the coolant. I'm not a flusher as I don't like the idea of tap water getting trapped in the engine. Anyway, my Helm manuals haven't arrived yet, but I figured all GM radiators have a drain on the side. This one seems to have two holes in the shroud, one on the corner and one more where the radiator seems to be, the hole being almost blocked by some frame rails. Anyway, I figured the blocked one was the place, and there appears to be a stripped out plug there... Is this the correct place? If so, I guess I'll have to try to remove it and get a new one. :-\ I did suction out about 1/2 a gallon from the upper fill tank, and a little under 1/2 a gallon from the overflow tank. So at least there is a little fresh coolant in there. Man, you can't get plain old green silicated coolant anywhere now. It's all Dex-Cool, or non-Dex-Cool "extended life". I got some Prestone non-Dex-Cool extended life stuff.
A few things I noticed were the oil dipstick sure is hard to remove without getting oil everywhere. And removing a panel to get to the battery always makes me wonder. I mean, the car isn't that small in overall size. Yet the interior is small enough that the seats practically don't fit in it, there's no trunk, and you can't even pull the battery out without removing body panels. How the heck did that happen? Lastly, my front GS-C's are mounted on the wrong sides. They roll the right way, but are on the wrong side. I'll pull the rears and check the manufacture date. If they are more than about 7-10 years old, maybe I'll just get all new Supercars instead of paying to remount and re-force balance them.
