Paul G
1996 LT4
Can the trans come down with the shifter still attached? That is the question.
We have the exhaust off, console apart, getting ready to remove the drive shaft and C-beam. It does not look like there will be enough room to slide the trans back far enough to come down with the shifter still attached. Does the shifter have to come off before you try to slide the trans back away from the engine or will the engine tilt backward far enough for the shifter to come down and clear the hump?
