T
theblackvette
I reported some time ago (not in this forum) about a Charge System Fault message that I was receiving on start up at least once a week.
I took my Z06 in several months ago and had it checked out. They tested the amps and everything seemed to be cool. They did however tighten some cable underneath the car. After they tightened it, I have not seen any more messages.
Therefore, I think I can conclude that it was a loose cable that was causing the messages to appear. I recall some Z06 drivers getting this message on a regular basis as well. If you are still getting your message, you may have you answer as to why you are getting it.
Hope this is helpful!
