J
JOE BYRNE
So after figuring out that my power window relay was bad through jumping it I have one more question. Domes were on for quite a while and turned the key to the on position quite a few times for testing. Put it back together started it up and ran it around for about 25 minutes. Amp gauge is at positve 40 and has not dropped down yet. It is charging at about 13.2 from the alternator at about 1500 rpm. Im just thinking I did not run it long enough since it is only 20 outside. Battery is getting up in age also....although everything was bright during the drive...sound normal??:crazy
