BC-2011
I am new to this site but i have use it and it is awsome. I bought a 81 vette 350 manual transmission for the wife(she always wanted one) Had to get it smoged well in the CA the check engine light has to work so i failed before i got in the door. I used this site with all the awsome support. I did all the things the posts said to do and ended up putting in a re-man ECM. The check engine light came on and when you started the car it went off GREAT all fixed. I had it smoged and the smog guy said it passed smog but the check engine light is on and we cannot get it to go off. The only thing he said he did was unplug the distrubitor plug with the engine running and the check engine light came on like its supposed to. He plug it back in tried to disconnect the NEG side of the battery to clear the code but it would not clear. I took it home jumped the plug under the ash try and it gave me a code of 15 and 55. I changed the temp sensor Code 15 and the 02 sensor code 55 and still the check engine light stays on. I cleared the code and still the check engine light stays on. I check the codes again and it still is giving the same codes 15 and 55. I have checked all the wires and they are good. The engine runs great with no problems. Any help i can get would be appreicated.
