- Thread starter
- #21
So all I need to do is adjust the TPS and I am all set to go except maybe backing out the idle screw correct? How do you reset the TPS, reset the battery?
Sorry, I meant recalibrate the TPS by rotating it back to book value.Vettefan87 said:So all I need to do is adjust the TPS and I am all set to go except maybe backing out the idle screw correct? How do you reset the TPS, reset the battery?
wishuwerehere82 said:Sorry, I meant recalibrate the TPS by rotating it back to book value.
vetteboy86 said:Well I am not sure who is right or wrong in this matter, perhaps nobody. However the TPS is basically a variable resistor, or a potentiometer. Over time moving the wiper, age, and other things will change the resistance of this resistor. So it would make sense that GM would use a window, or somekind of limits for wot, and the idle. I am not sure if they did, but to have it set once at the factory, would warrant us all to check ours yearly to make sure it is still in spec.
OOPS, that is what yours is set to now. Set it to what the book value indicates. If that is 0.580V so be it.Vettefan87 said:I am pretty sure it is at .54 volts now. I thought I read somewhere here it was best to be at .58 volts?
Stevebradfordsvettes said:there is a procedure in the manuel for setting min air rate if it is not set correctly all sorts of drivability problems can crop up if any one wants the proce dure i will be more than glad to post it .in my opinion slight voltage variations one way or another is not counter productive in my bookSteve
