Edmond said:How much are we talking about for a new TPS?
Vettefan87 said:I don't know if this is what I need or not. If so it isn't that much... http://www.madvet.com/shop?frame=3.900
Moonunit 451 said:They can be tested, but I don't recall the proceedure. Also, I think you can pick one up at a local parts store, maybe they can even test it for you.
stevewishuwerehere82 said:If you can get some time on a scantool, it will tell you TPS voltage, Fuel/air mixture, O2 voltage, whether you are running open loop or closed loop, Timing, and a whole bunch of other stuff. It will give you all the info the computer has at it disposal. Get your rocker issues fixed first, then scan it. See if you can get some highway time with the scantool hooked up. That may give you some insight into what is happening with your power curve.
Okay, maybe we are getting somewhere now... How would I adjust this to get the extra little voltage out the low side, and the little over half volt at WOT? Wish, could you explain how you filed the slots? I am sure the TPS sensors are similar for your 82, and my 87, if not identical. Thanks.
