M
mikewin
i have a 98 corvette, an i would like to no how to check the fluid.
i read around that you check it running, an hot. i put it on the lift,
started to pull the plug out, an transm fluid started to come out.
so i turn it back in. it has 60,000 miles on it, an the flud looks good, that drip on my hand. what i would like to no if its overfull.
an should it be coming out of the drain plug. an should i change it.
:confused
:confused
