Peer81
Hello everybody,
Small problem with my quadrajet. The problem is the same from the first day I have the vette, not a really big problem but now that the vette is almost finished also the smallest problems need to be fixed.
Last week I reset the choke by Lars doc's, corrected the choke valve to get the ideal cold mixture with the screw on the front vacuum pot. The electrical choke is set a little les then stock to let go of the choke a little sooner. I set the choke RPM to 1000 to 1200 and the normal RPM to 650 - 700. Now the problem, when I start the engine cold the choke doesn't kickin from the beginning, she starts "idling" at 550 and after a few minutes the choke kicks in.
Why isn't the choke kicking in from the start?
How does the choke get on the second or highest choke ramp, I think it's the spring load from the choke that "forces" the throttle linkage to get on the second or highest choke ramp but I doen't understand why this happens after a few minutes.
I already checked the choke element putting 12v on it for a while, and the choke spring moved about 2 inches if I remember correctly.
The q-jet has been rebuild by myself, also the vacuum system and all other things are fine.
Greetings Peter
Greetings Peter
