Choke light does not come on
  • Thread starter Thread starter 81kix
The choke light gets its power from the 20 amp "gauge" fuse. This fuse also supplies power to the console gauges. If your console gauges seem to be working, then the bulb could need replacing. If your console gauges don't work, then check the fuse. But now the next question is to determine why the fuse blew. If that's the case, I will walk you through it.
Good luck!
Vettenick
HI there,
The gauges are fine and I know the fuse and bulb are not blown, because when I turn the key to start the choke light comes on. The second my car starts the choke light if off. Strange and still puzzled.......Janine
i could be wrong but sounds like correct operation steve :w
Well.. It's pretty cold here in PA. in the mornings, just like New york and I would have thought it would go on at least then......Could I be wrong? ;shrug
it should come on with a bulb check with key in the on position then go out when the car starts glad to have met you in carlile i willpost pics soon steve:beer
Thanks for all the Info.
Hi Steve, it nice to meet you too, in Carlisle.
Well, then I feel better about knowing that my car is fine. Some how in my silly brain I thought the choke light should of gone on for a few minutes till car warmed up. One less thing to fix LOL
:w
