Getting ready to install the choke tube setup that goes through the manifold and connects to the AFB carb choke on the top side and loops underneath the manifold and goes up to the vacuum connection on carb.
- Any advice on installing this setup? Since it goes up to a vaccum connection does it stay vacumm tight going through the manifold?
- I have noticed on some pic's an insulation type cover on the tube going from the manifold and the choke input, I have not seen anything of this nature in the AIM about an insulation cover of any kind, is this necessary for protection from the heat from the manifold?
- Concerning the tube going through the manifold does the top and bottom tube mate into it or does it slide in the manifold next to the inside manifold piece and hold tight by itself. I know the bottom tube has a hold down bracket that holds the tube setup in place but does it just slide up in the manifold and seat itself?
- Does the tube portion that goes into the manifold install best from the top or the bottom of the manifold?
- Should the connections on the top and bottom of the manifold be sealed in any manner once installed? Thanks for any input.
