most of the hardware such as the bolts, washers, studs, etc for the parts i've taken off the motor I ordered new replacement items for. These include things like new intake bolts & washers, valve cover bolts, all new exhaust manifold bolts, washers, french locks, studs and nuts, etc so everything will be fresh, clean and easier to deal with when it's reassembly time.
There are some small items that I didn't see the point of spending the money for new replacements and now I'm wondering the best way to get them cleaned up. Things like the bracket that mounts on the intake that the throttle linkage return spring attaches to, the ignition shielding brackets, alternator mounting bolts, some hose clamps, etc.
I obviously don't have a parts cleaner like some of you guys that to do a lot of your own work have but need something that will clean up these small pieces.
Would one of those one gallon carb cleaner buckets that comes with the carb cleaner solution in it with a basket work or am I better finding a local mechanics shop that would be willing to put these parts inside one of their parts cleaner machines be better?
