1
1on2off
Hi, Guys and Girls. This is my first posting re: a problem with my '94 Coupe. It's been stored for about the last 6 months and I just put it back on the road to move to my new home. Started great and then parked it outside the garage while I went for insurance and reg. It poured that night when I went over to get it to bring it to my lift to change oil, etc. Started fine, again, but stalled about a block later. Hard to restart but got it home. Took it to the garage next morning to have the SES light decoded. My buddy told me a code 36, bad Opti. I brought it back home to regroup and look for a unit on the internet. I've been reading as much as I can and I'm 'Optied' out. Here's a question, is it possible to pull the cap and rotor from underneath without going through the whole Opti disassembly procedure? Is it possible I just have a cap/rotor problem or almost certainly a new unit? Right now, the car will always start after exactly 5 seconds of cranking and seems to run real strong, although both cooling fans come on right after it starts. I was told it's running in limp mode but the way the car runs seems to defy that reasoning. BTW, the engine in the car only has 27k on it and paperwork from the original owner shows a second Opti installed that now should have only 9-10k on it. Another question, how bad can the Opti be if the car starts and runs at all? I've heard most times that the car just shuts down and that's it. Sorry to be lengthy but I wanted to get all my points across. Ed.
