80VetteL82
Okay so once I pull the motor out of my car, I figure it will be a great time to really clean up and organize my engine bay. I figure it would be a good idea to also clean and paint the section of the frame exposed in the engine bay.
Im just looking for advice on good ways to go about doing this.
This is what I planned. I figured once the motor was out I could take a wire wheel to the frame and really clean it up. Once all the grease, oil, and any surface rust is cleaned I was going to go with POR-15's black coating. Do you think I would need to topcoat the frame after the POR-15, or does that leave a good enough finish on its own? For the bay, I figured just a good cleaning and then paint with a high temp black paint. then Ill organize all the vacuum lines and wiring, and replace any necessary....then I should be ready for the new motor....
Does this plan sound like Im headed in the right direction? Any suggestions?
Thanks, Kevin:cheers:
