D
devilfish
Ok now I know what my clicking probleme is..
I got a "click" sound when brake or turn hard after my clutch work ( clutch engage ).
And when I apply the clutch pedal, 5mm is enough, the sound dissapear.
Had the FW machined down, and a new GM clutch and PP installed.
The machine shop know about the dampening material so they used a "water" based kind of oil , what ever...
I think that the material the machine shop took away from my FW whas to much and causing the throwout bearing to rattle against the pressure plate fingers.
Now how to solve this?
I dont think it can damage anything, but its pretty annoying. So let it be?
Or mayby I can "file" 0.02" on the PP bolt holes, allowing the PP to come a bit closer to the FW to make up for the "play"? Sounds like a creative solutions, and mayby it can damage something?
Or mayby I can make the throwout bearing "stick" thigher to the PP using some kind of brass tube on the clip that holds it to the PP ( se pic ).
Or get a new FW for $900 yeah right...
A used FW from the scrapyard and have it balance just like my old FW? Is that hard to do?
Well thanks for reading...
