Climate control HVAC blower control module - where is it?
DarkkHelmet
New Jersey
2001 C5 Magnetic Red II Metallic
I have not been able to determine the cause of the blower failure and have decided to try and replace the most suspect part or parts. Before I remove the blower motor again I was hoping someone could tell me where the speed control module is (resistor). This is a dual zone climate control auto trans 2001 C5. From what I can recall the connector for the blower is coming out of the wiring harness and not directly from the module. I can not see any module even with the blower removed. Also, is there a way to determine the OEM part numbers without removing the parts? Thanks
