rkortge
Is my 81 supposed to light up the climate control panel? Its dark and wondering if there is a bulb that's out?
Rich
			Rich
I replaced my climate control downfire bulb with an LED, and drilled the downfire hole to be about 25% larger. It is a beautiful thing to actually make out the climate controls at night. Its the one thing on the C3 that is a sure sign that Zora Arkus Duntoff never test drove his prototypes at night for some reason - or he would have noticed the poor design immediately and challenged the obviously novice lighting engineer to make the downfire lighting hole to be large enough to actually light up the climate controls. It is a very easy DIY fix that, oddly enough is not posted on any forums so I had to `invent' it myself. Lucked out.Thanks
Do you have a picture of the result in the dark without flash? I sure like the sounds of it
Greetings Peter
So what I hear you saying, Zora got the important stuff right.
Looks good to me.Here you go - this was taken this evening. I installed 5 DIM `warm' LED lights in the gauge body a few weeks ago, and a basic Federal Mogul (Wagner brand, I think) LED in the downfire socket after drilling it out about 25%. You might think that it looks bright in the picture that was taken with an iPhone 6, but in actuality it is a very pleasant, easy on the eyes basic brightness level while driving in the car at night. It is not as bright as the instrumentation in my new Ford Taurus, but it is perfect for me in my C3. I need to do the same for the speedo/tach one of these days. Hope this helps, as requested.
Dave
 ...Its the one thing on the C3 that is a sure sign that Zora Arkus Duntoff never test drove his prototypes at night for some reason...
Zora Duntov had retired from GM before your car came out. You can't blame him for 77-82 HVAC illumination.
 Keep in mind Zora Duntov had a lot of things he had to live with and could not change.  He had to work with what he was given.
