Close Call
  • Thread starter Thread starter Dave L.
They are $35.00US (lifetime warn.), for the clutch part of the fan down here in lower land. Is the price that much higher up there?
I picked up an original AC-Delco replacement(GM# 14047080) today for 49.49 + tax at my local AC-Delco Distributor. It is the correct replacement with the proper 2 letter stamp code on it. Not that I am an original numbers mathcing sort-of guy,I just like using factory replacements whenever possible.
Dave
I've already looked locally for a 'proper' replacement, Even the Chevy shop couldnt get one for the 75 w/AC which leave me again with little options.
Ecklers to name 1 company lists it at I think 140 US for the model w/AC
I suppose I could even get on of the other models but those still go for 80 a pop.
Translate that into shipping, brokerage, and currency conversion.. OUCH :duh
Bill
fan clutch for Bills '75'
Bill- Tell your chevy shop to look again. That clutch is available for your 75 w a/c. GM# 12529342 retail $99.73 trade $ 69.81. Let me know if interested.
Dave
AC = Air Conditioning
PW = Power Windows
PD = Power Doors
PS = Power Steering
PB = Power Brakes
NOM = Non Original Motor
These abbreviations you will most commonly find when looking in want ads.
:D You know, it's a funny story. I'm looking at this fan clutch thread and seeing AC, and I'm saying to myself, "what does air conditioning have to do with a fan clutch, besides the cooling aspect?" So, that was my first initial inclination as to the abbr., but then I dismissed it because I couldn't see the relation.
So, how is the AC related to the fan clutch?
Give me a paddle,
I'm in your boat, too!
I've got no clue! :D
I think it may have something to do with belt routing? I really don't know.
Heidi
Sallion... Are you up to your old tricks ...Wth a trick question. The clutch their talking about is on the front of the engine for cooling the engine not the clutch that you depress with a pedal
No, I know. I know they're talking about engine cooling, not the pedal. But, what does AC have to do with that engine cooling clutch? That's my question. Thanks! :)
Stallion- A car with AC puts more strain on the cooling system due to the need to drive the AC compressor. There for, a fan clutch that locks the fan in to the "drive mode" at a different temperature is needed to pull more air in across the radiator to keep the car from over heating.
Dave
So I guess then it's the most opportune to get a fan clutch with AC? I think I understand. Thanks! :D
Stallion,
It seems you have a interest in cars in general. I would suggest that you pick up some books and do some reading on engines and cars. Doing that will answer a lot of your questions and also bring your questions up to a higher level there by speeding up your learning. Good luck and don't get discouraged because we all learned somewhere.
Thanks! I actually just ordered a book from Richard Newton on Restoring and Modifying your Corvette 1968 - 1982 so that should give me a lot of info on the Vette, and parts in general for me to work off of in my learning. Thanks again! :D
As many of you know I am an auto claims adjuster and thus investigate and handle the aftermath from auto accidents/injuries.
I had a really strange case this last year. A fellow upon the suggestion from his auto mechanic replaced the stock fan clutch set up on his 1991 chevy 4.3 blazer with a flex fan about four years ago.
The engine had been running kind of rough, and he took the blazer back to his mechanic to check it out.
The owner of the shop is about 65 years old, heck of a nice fellow. He had the hood up on the blazer, engine running, and he was holding the RPM higher than idle trying to diagnose the miss in the engine. Without warning, he hears a strange sound and lets loose of the throttle linkage to see what it was. When he looked down his left arm was resting down in the engine bay and he was squirting blood all over the shop like a stuck pig. He never felt anything but a dull thud and heard the noise.
What happened? The flex fan fractured at the hub area right where the blades come out of the hub and do most of the twisting as the engine speeds up and slows down. The blade came out like a butcher's knive and cut his arm off above the elbow clean. It could not be reattached due to other health conditions that this fellow had been suffereing.
He nearly lost his life, as he was having problems with his diabetes, heart, etc. and the blunt trauma to his system nearly over loaded him.
So, this further reinforces why I am a proponent of electric fans whenever possible, and I try to avoid staning in the fan blade/belt path of an engine while it is being revved.
Hmmm, made you think twice about that flex fan....didn't I?
Wow, it sounds like fan clutches have a pretty clear path right through the dashboard. I guess, 69MyWay, you don't suggest using a flex fan clutch?
Stallion - A flex fan is used in place of the standard fan-clutch set up. The blades are 'flexible' and flatten out at high engine speed or rpm's. The fan blades on a stock fan are very rigid and do not bend. When the engine is idling or running at low speeds the fan-clutch 'locks' the fan in to a drive mode to pull fresh air in across the radiator. At high engine speeds when the car has air moving across the radiator due to the speed of the car the fan-clutch releases and alows the fan to free-wheel thus putting less load on the engine,thus attaining the same result as flex fan blades flattening out.
Dave
Well Said
Nice job Dave. Our young friend Stallion is craming knowledge as fast as he can get it. For someone not knowing anything about auto's as we all did at one time or another, all the help he can get is appreciated. He needs to know basics, then go from there. He's a sincere enthusiast whom I help every chance I get, I hope all our other members can take a little time and do the same for him.;)
