M
Mungo 75
I just installed Dynomax ceramic headers on my 75 small block and the clutch
cross shaft really rubs the last tube on the header. The stud that screws to the block is fixed and the frame side reciever has the stud bottomed out not leaving any play at the headers. I wondered if extending the frame hole further down would solve my problem, (although the shaft would be askew),or does anyone else have a better solution? Thanks for any suggestions.
PS. If you suggest bending the header I was concerned that the ceramic might be damaged and lead to other problems, and bending the cross shaft might lead to shifting problems.
