Question: clutch issuses 79
mirrorman
essex md
1979 Black coupe
Last time i drove car it shifted fine.Parked it for a month and when i went to start it with the clutch pedal in it tryed to lunge forward.Is this more than adjustment or is it time for a new clutch.
If the clutch pedal effort felt the same but you pushed in the clutch, fired the motor and the car took off the clutch disc is probably "frozen" (rust or other contaminants) to the flywheel.
I'll check that this weekend.Pedal felt normal except you can;t put in gear with it running
Thanks Again
