dshanks
JohnZ said:Assuming you have the original flywheel and bellhousing (and you don't have an original LT-1), you need the 10.4" clutch; your flywheel doesn't have the holes drilled for the 11" clutch. The 11" clutch requires a 14" 168-tooth flywheel (and a different starter), and that flywheel won't fit in your bellhousing.
At the time I wrote this, I didnt know that the clutch was dependant on the flywheel size, not the transmission. Since then, I spoke to my engine builder, and he said that the flywheel on my new motor can use either a 10.4" or an 11" clutch, so I assume its the larger flywheel with the holes. Right now I have the stock setup, will my starter fit an 11" flywheel? I dont want to replace the starter if I dont have to, and I know the original flywheel needs work or replaced, what should I do?
Replace the new flywheel on the new motor with ANOTHER new flywheel, replace the starter, or will my starter work fine with the new 11" flywheel?
