Anyone out there know a trick to replacing the clutch safety switch. VERY tight place to get the switch out, not to speak of putting it back in?
I did this on my 89. There is no other way to do it than squeeze your tiny little fingers up in there and do it. Actually, I had a friend with smaller hands do it for me. It is really hard to do unless you're a contorsionist and have the patience of Jobe. Good luck.
The only thing I've heard of that helps is to Remove the Drivers Seat for more room to get up in there.
I've even heard of removing the Clutch Pedal & Bracket, but that seems like more work then it's worth.
Thanks guys! Yep, it's WAY up there. I used a flex shaft socket extension and fish hook remover to remove it. It indeed is like performing surgery from a remote location while standing on your head, LOL. The replacement is forcasted to be equally as delicate.
Tom
