- Thread starter
- #21
John Robinson
Gone but not forgotten
I am not sure but I went and looked at the vacuum lines that feed the egr solinoid and the vacuum reservoir tank. What I found was the line from the vacuum port to the vacuum reservoir broke or came apart when I moved it. Later today I may be able to start the car and see if it idles better. I well let you know the results. If only it were that simple. Actually it makes sense that would cause a code 32. That line comes from the manifold with a tee that runs vacuum in both directions one to the vacuum reservoir and the other to the egr solinoid. So in effect the egr solinoid never gets any vacuum if that line is sucking air.
