R
Rock Doc
Anyone have any experience with code 42?
Thanks, Rock Dock
Thanks, Rock Dock
When the system is running on the Ignition Module, that is, no voltage on the bypass line, the Ignition Module grounds the EST signal. The ECM expects to see no voltage on the EST line during this condition. If it sees a voltage, it sets Code 42 and will not go into the EST mode.
When the rpm for EST is reached (about 400 rpm) and bypass voltage applied, the EST should no longer be grounded in the Ignition Module so the EST voltage should be varying.
If the bypass line is open or grounded, the Ignition Module will not switch to EST mode, so the EST voltage will be low and Code 42 will be set.
If the EST line is grounded, the Ignition Module will switch to EST , but because the line is grounded there will be no EST signal. A Code 42 will be set.
