A
Andy C
I have a 1990 6 speed with a cold driveability problem. It starts right up but if the temp is 40 or 50 degrees outside it has a terrible stumble when starting out from a stop and then a hesitation when shifting from gear to gear.
I started out by replacing the air and water temp sensors. After that didn't help, I replaced the TPS, and the MAP sensor because it seemed like a fuel mixture problem. Car is low miles and spark plugs are clean. I'm at a loss as to what to look at next. Distributor/coil/ignition module maybe? How would I check that?
