communication with the ECM from the ALDL interface
this is what the tool came out with
need help with areas to solve this problem
More info needed
What tool?
What software?
What cable??
What ECM?
"communication with the ECM from the ALDL interface
what about it ???
a snap on 12 point code reader said that there was miscommunication with the server possibly bad computer i believe code 12
So check the ECM's fault displaying capacity by doing it the old way.
C4 Corvette Diagnostic Code Recovery Techniques
If you can't get the SES light to flash that way then you have problems with the ALDL connector or wiring to ECM from said connector.
If light flashes as it should then the problem is with your code reader or cable
