68vertible
- Joined
- Jun 17, 2005
- Messages
- 8
- Location
- Lavonia, Ga
- Corvette
- 1968 Roadster, '93 40th coupe, '07 coupe
I have a 68 327 and I'm about to begin evaluating the engine. I have never fired (or even turned over) this motor. I want to run a compression test, but know I need to ground the ignition system during the test. I have some sort of converted electronic pickup in the distributor and an ignition module on the firewall with Hays written on it. I just bought a new HEI tach drive distributor to replace all this, and I'm going to be reworking the Edelbrock intake (polishing the outside and cleaning up flow on the inside).
My question is, can I pull the distributor and manifold, then run the compression test with no ignition/intake or should I leave everything in place? If I do leave it in place, how should I ground the ignition so nothing gets fried? My first inclination would be to pop the plugs into the wires and rest them on the intake manifold so they ground but I want to keep things safe so I need to be sure. Another option I've considered is to remove the hot wire from the ignition to the coil, but not sure if that is correct for an electronic conversion such as this.
I really don't have any concerns about re-indexing the distributor after turning the engine over with nothing in the hole, I've done enough teardown/rebuilds that getting the dist in right is not an issue. I've just never gotten into ignition systems before (I've always had points systems in my prior cars) so the proper techniques elude me. Thanks for the help.
