S
sparky
Thanks to all for the help you have been giving me i checked numbers on car and you were right about late model production.
I figured the best way to do this was give you all the info i could on the car at one time. i was told by experts that the numbers do not match in several areas. Now you helped me with the rear end but now im confused in a few other areas that they tell me is not possible. they want to fly down and look at the car but i want to be sure it is what they say before i waste those peoples time. (to fly down is thier idea not mine ) i actually just want to build a car i can be proud of and this vette is just what i always wanted. but at same time if it is a part of history i am not going to ruin it.
So here i go with these numbers off the car and maybe that can help to erase the confusion.
VIN# 194379S733317 ( already know this is late 69 prod)
Engine ID # V0930GC..this is 1 of the confusing parts Number goes to a 350CI/300HP engine but on plate by shifter it says 350ci/350hp also on breather it says 350 hp turbo fire
Intake # 3927184...I can match it close to a 69 model but not exact.... also had motor checked it has 12 to 1 compression at least. Company who checked it is a friend and builds racing motors for talladaga ( hope that is spelled right )
Behind carb in between dist and carb is 1208 on a plate
On rear of plate that fits on center console ( where 350/350 is is a part number P-3963148 and also below that is P-3963154
Clutch measures 11 inches across ( not sure if that matters )
Spare tire is original i was told but it is a uniroyal tiger paw with 1" whitewall
Rims are AZ 1-9 9 with k-19 stamped by center ring
Bell housing #3899621
Brake caliper parts # 5452281 and 5452284
radiator is a harrison 4 core ( can look inside and see 4 cores )
All sheild for heat under car are aluminum.
Car originally came from OHIO too ( again not sure if that matters )
Fly wheel has 11 marks on it in 2 diffrent locations on side
Also M45 stamped on rear passenger side of motor above flywheel
Stamped behind flywheel on rear of motor are 2 sets Numbers
P-side H-39
P-side 010
020
Anyways i hate to bother all who are here for fun with my Questions But this seems the best place to get an honest answer. Also found evidence that there was a roll cage on car or it could be where normal wear is on the frame ill attach pic of that here. they told me it looked like roll cage was cut off and frame was repaired ? Im not sure what it is..there is also a better pic under 69 rear end confused post that shows it better on other side
Sparky
P-side H-39
P-side 010
020
Sparky
