ok, I'm getting fed up with this rebuilt carb already........
on my '65 L76 I have the correct Holley 2818 carb. Most may remember I sent it out for a complete rebuild earlier in the winter and it came back with a non-working choke which I had to repair myself and leaking (which it never did before the rebuild) which again I had to fix myself.
I've been fighting another constant problem in addition since it's come back and this one has me baffled.
I'll set the idle to the perfect idle speed for my motor - approx 850rpm. it will run and idle great for that day. The next time I take the car out and the car warms up the idle is up to around 1100-1200rpm. I'll reset it back to 850-900rpm. The next time the car is driven the idle is back to 1100-1200rpm again.
I've reset the d*mn thing 7-8 times already and only driven the car less than a dozen times this season! Pretty much every time I go to drive it I need to reset it.
Last time I drove the car it was idling high again so when I got home I put the idle back to 850-900rpm.
I just went out to the garage tonight to check everything on the car over for the cruise I plan on taking in it tomorrow and when i started it and after the choke came off the idle was down to about 550-600rpm which is way too low for an L76 to idle. I figure it's low because I had to reset it down after it was too high the last time I drove it.
With the spring on the idle screw there is plenty of tension so I don't think the idle screw itself is moving so why is this doing this and constantly changing the idle speed on me each time I drive the car.
This is getting to be very annoying even if it does only take a minute to readjust it. I shouldn't have to do this everytime I want to drive the car!
