Florida Guy
I had my oil changed yesterday at a dealer and the technician put in 6 quarts of oil instead of the 4 1/2 that is required. I drove it home - approximately 34 miles and parked it in the garage. After about 20 minutes I decided to check the oil level. I don't know why, but I found the level way up the dip stick. I then checked the invoice and found they put in 6 quarts of 5W30 Mobil 1. I then looked at previous invoices which indicated they put in 5 quarts. I won't get into what transpired during the subsequent phone calls to the dealer's service department. I drained 1 1/2 quarts in my driveway. The dip stick reads full now. This morning I drove it to another town about 50 miles distant. When I returned this afternoon, I monitored the coolant temperature on the Interstate. Max was 212 degrees. The oil temperature got up to 215 degrees. Close to home I drove at 30 mph through a residential area in 2nd or 3rd gear. The oil temperature got up to 228 degrees.
My questions for those of you with experience: When I drove it home with the 6 qts in the crankcase, is it likely that I damaged the bearings? I am concerned that the oil may have foamed and lost it's lubricating properties.
And is 228 degrees within the normal range for that oil in the above driving conditions? Seems high but I don't recall ever checking my oil temperature under those conditions before this.
What do you think???
