I have a problem with a headlight coming up and the motor keeps running and the only way to make it stop is pull the fuse or disconnect the battery. The other headlight works perfectly fine. The plug right behind the motor has five wires going into it and I tested it and compared to what the other side was doing and slots marked A and B on plug read different from both sides. The side that works has volts (26.3-27.4) both to A and B...C,D,E are 0 while car is off and the side that keeps running only has full power to B volts (26.4-27.1) and the A slot only reads (1.1)...C,D,E are 0.
