This can be a pretty large job. Mostly because the car is down while you are making the change, and that means it is stuck in the driveway with no front wheels. It is also dangerous working around the front springs and the weight of the car.
It is best if you have a press available, or at least a good work bench area, strong large vice, plenty of hammers, pry bars, and if not the tools, at least access to renting good suspension tools.
It is a 15 hour job,,,,,,,I don't think so, but it basically requires yanking the entire front end out and putting it back, then a quick trip to the alignment shop.
I would plan on two weekends. One to tear it down, the work week to run down any extra parts or tools, then the next weekend to throw it together.
