I had my front end "professionally" replaced last spring at a performance shop. The replacement was with Poly bushings. The lock washers were not replaced nor was loctite used on the threads. Before I knew I had a serious problem, The Driverside upper control arm bolt's nut loosened and came off, then the retainer, then the front bushing spit out , causing the wheel to flop. I was lucky and found the problem before any destruction to the wheel assy. happened.
Jack is absolutely correct, with what he's saying and I have of course replaced every lock Washer and nut and used loctite on all the bolt threads for upper and lower control arm assy's.
Hope this helps..
Tom
