C
cruisin-davey-g
Hi:
If you left the trans in the car, how are you holding it up?
OK............I replaced all of my upper & lower control arm bushings & used poly..........I also replaced the sleeve.
Poly will make your ride somewhat stiffer than factory type bushings.
The only paint that I would recommend using would be Por-15
This stuff is great. You can brush it on right over sand blasted parts (using metal prep first) & it will come out looking real nice.
But, if you spray it on........then it'll look like the show cars you see & in the magazines.
You can get gloss black, but I would recommend the Chassis Black.
Stuff looks great.
Wouldn't use anything else!
Stuff looks great.
