Capt. Mike
- Joined
- Feb 21, 2008
- Messages
- 11
- Location
- Oxnard, CA
- Corvette
- 04 Med spiral gray Vert/95 comp yellow Vert
I haven't faced this problem yet, but I've used 3M Windoweld in similar circumstances. It's used for holding in windshields, so it's strong and flexible. I used it to build new motor mounts a few years ago, and they're still working! The stuff is black, so if your top is also black, it will be invisible unless you are extremely sloppy in your repair.
with all the big dollar amounts being thrown around to replace a top, how hard can it be to buy the top and install it yourself?? Any experiences?
I used 3M #08609 Window-Weld Super Fast Urethane and 3M #08682
Single step primer. Be sure to clean the edges of the glass where it contacts the top and apply a thin coat of the primer, it helps the urethane to adhere to the glass. I used this on both my C4 and C5 and it is a permanent fix.
