82shark said:
Now that pollen season is finally over, my black soft top is looking a little dingy in the fabric. I've washed it w/soap and water but don't know if thats the best thing for it. Are there any cleaner/conditioner type products that will protect it and make it last for nearly eternity? (cause I can't afford to replace it ;-)
Ed
Wolfsteins.com (Wolfstein's Raggtopp)
Wolfsteins Pro Series
310 Quiet Water Lane
Atlanta, Georgia 30305-3723
(770) 395-0020 or (800) 377-4700
info@wolfsteins.com
A little added info>>>>>>>>
[font=Arial, Helvetica, sans-serif]HOW TO APPLY [/font]
RAGGTOPP Fabric/Vinyl Cleaner
• Wet Convertible Top thoroughly.
• Spray and apply evenly over entire roof and scrub lightly with soft nylon brush.
• For very difficult soiled areas, spray and let stand for 15 to 20 minutes. Scrub lightly with soft nylon brush.
• Rinse thoroughly with water until no remaining soap foam is observed.
IMPORTANT: CONVERTIBLE TOP MUST BE THOROUGHLY DRY BEFORE USING RAGGTOPP PROTECTANT
RAGGTOPP Fabric Protectant - FABRIC TOPS
• Start with a clean dry convertible top.
• Shake well before use and several times during spraying.
• Hold can upright and spray evenly 16-18 inches from material.
• Spray three light even coats of RAGGTOPP Protectant using gentle sweeping motion. DO NOT SATURATE.
• Allow to dry 10 minutes between coats in the sun. Artificial heat can be used to speed drying time.
USE A CLEAN COTTON TOWEL/RAG or MICRO FIBER TOWEL TO WIPE OFF ANY OVER SPRAY
Use RAGGTOPP Vinyl Protectant for Exterior/Interior Vinyl Protection
[font=Arial, Helvetica, sans-serif]How To Apply On Vinyl [/font]
• Wet Convertible Top.
RAGGTOPP Vinyl Protectant - VINYL TOPS
• Shake bottle and spray 8 -12 inches from convertible top.
• Spray on using gentle sweeping motion or spray onto clean cotton rag or towel and wipe onto vinyl convertible top.
• Wipe dry with clean cotton towel, rag or micro-fiber towel.
• Apply every 4-5 weeks for maximum UV protection against the elements of nature and man.
For Fabric Tops Use RAGGTOPP Fabric Protectant
