cinci5
Where'd the rest of that article go? I thought it had a good description of actually balancing the TBs?
if you click on the pictures on right and left the rest will show up relating to pictures
I say repin the ecm harness and run a 7747 ecm made my cfi run alot better also get the water temp up on it that helped my idle considerably. The ecm upgrade is the best thing and will allow you to have a prom custom burned for the car. My CFI ran pretty strong after these mods and a TPI fuel pump.
You replaced the wiring harness connector?
When I did mine I had bought a adapter that plugged into my factory harness and plugged into the 7747 is all. I no longer have the car though. But, these 3 changes made my CFI run extremly well still not fast but driveability wise it was very nice verses stock.
I have seen this one from Turbo City. Basically an ECM swap out for a faster one. Repinning harness instructions included.Where did you get that adapter?
I haven't seen that one.Oh yeah I'm very familiar with that setup...WHAT a ripoff!
I don't think that's what he was referring to though... :confused
I was just wondering if he had one of these:
http://www.speedtronics.net/aboutham.asp
I put one of these on mine to cure the "bucking bronco" syndrome I had at high RPM's when I let off the throttle.
http://www.mamotorworks.com/corvette-4-0-858.html
did it actually do anything??![]()
Well when it came time to do the ECM swap myself...I just could NOT see hacking up my harness, so I developed that. Works quite well!
If it does then it's only masking some other existing problem. That thing is nothing more than 10 cents worth of resistors (and apparently $60 worth of connectors :eyerole ) that make the ECM "think" it is at WOT when it actually isn't. Bad idea if you ask me.
All I know is that it worked when I used it.Well when it came time to do the ECM swap myself...I just could NOT see hacking up my harness, so I developed that. Works quite well!
Yes that is what my car had .... As for fuel mileage took it to san francisco once and it maintained about 25.5mpg at fillups.
One thing I did want to add though is don't use a camaro 8746 ecm. because of two reasons one being VATS and the second being the 8746 requires IAT sensor input and to do so you need to run extra wires to the air cleaner. Without this the 8746 will keep the car always wanting to idle high. 7747 doesn't require this input though
