D
DMGroh
I pulled my resevoir this past weekend. Same problem. The tank was fine, the overflow hose clamp needed to be tightened. Also, the flashing from the mold on the nipple of the tank did not allow for a good seal. I hit it with emery cloth and retightened everything. So far no leak. But, I am having fun with the "valve, heater, water flow" that is in the heater hose between the core and the pump.
Seems there is a check ball inside that plastic valve that got loose and is somewhere in my coolant, hopefully the heater core and not the water pump.
