Cooling Fans
The 5 amp fuse if for the control of the fans. This power goes to the coils on the 3 relays. The relays are controlled by the pcm. The pcm grounds the wire from the coil to energize the relay. There are 2 outputs on the pcm, points 10 and 11 on the "red" connector, C1. The other 2 fuses are for the fan motors.
When the first relay is energized, both fans are connected in series and run at a lower speed because there is only 6 volts across each motor. When the second output in inergized, the other 2 relays also energize and the fans are then switched to full 12 volts and run in high speed. I do not remember the wire colors off the top, but I can look them up if you desire.
BTW. because the control is by the pcm, it is the coolant temperature that the pcm sees that triggers them. I would have to look them up but these temperatures are programmable if you have a Hypertech or similar.
I hope this helps.
Dennis
GrandSport 598
