89blackvette
I have 1989 Vette that has a fan problem, perhaps you guys can help. Cooling fan comes on at 124 (gauge display) degrees with AC off. Turning AC on makes no difference. My scanner says temp is 242 when engine is stone cold and fan starts at 248 (scanner display) when started. Scanner also shows fan request is on when fan is running and off when it is nit running. I have replaced the temperature sensor in front just under the throttle body with same results. Gauge temperature seems to be correct. Scanner says EPROM is 3291, what is that? Just do not want to work battery, alternator and fan motor more than necessary. AC blows cold and appeares to have never been tampered with. Could it possibly be the AC fan switch that turns on fan on AC is on? Thanks for your time.
Mike
Mike
